So just wanted to post real quick about my recent experience. I have a 22k 16x32 vinyl pool, that I've owned for about 8 years now. Over the last couple of years, when opening the pool in summer, I would perform a SLAM, and always end up with clear green water for a week or two and then it would clear up.
Last year I scoured this forum for answers and all roads seemed to lead to metals/copper in the water reacting to the high chlorine levels. Last year I just let the chlorine levels drop, and everything cleared up.
This year, same SLAM process, same clear green water, except this year, the green was a bit cloudy and has lasted for a month plus (Started SLAM beginning of May). I ran the SLAM chlorine levels for weeks, and then let them drop to normal levels, no change in slight green color in water.
I took a water sample to Leslie's (yes I know but I don't have a metal test kit), and they came back with some interesting results. Unfortunately I don't have the read out anymore, but the two interesting results were that I had about .3 ppm metals and 7ppm calcium hardness. The guy even commented on how low my CH was.
The Leslie's guy recommended some metal remover and the remover bags you put in the skimmer, and about 60lbs of calcium chloride. I ended up buying the metal remover stuff right away ($$$$$$$), but ignored the calcium hardness increaser based on the reading I've done on this forum around low calcium hardness not being important in vinyl pools.
Cut to two weeks later, no change in water color after metal treatments. I decided to tackle the CH issue because it was so incredibly low. I bought 50lbs of Pool Mate Calcium Increaser, and added 25 lbs of it last night to the pool.
Woke up this morning to completely clear ice blue water. Literally over night.
I'm heading back to Leslie's in a few to get updated test results, and I'll post those when I get them.
All of this to say that good water chemical balance across all chemicals seems to be more important than you think!
