I think it might be but I'm not absolutely sure. Hopefully one of the chemistry guys (help Richard!! ) will come along and enlighten us as to what's going on.
Butterfly said:Well, I don't know what those chunks are, but when we cleaned out our light niche, we found chunks of plaster that the plaster guys did not clean out.
And, the light guy did not clean it either, when he came to re-install the light after the replaster.
linen said:Assuming your OCLT is less than 1 and your CC stays below 0.5, then as long as there are no signs of algae, and you water is crystal clear, you are done with the shocking process.
When measuring high FC levels, or measuring FC when the CC level is relatively high, it is important to move through the test quickly. Drops should be added about once per second, or slightly faster, swirling the entire time. You can slow down a little at the end of the test, to give you time to watch for the end point.
At your high FC levels you may need two scoops.The exact amount of R-0870 powder used is not critical. The goal is to add more than you really need rather than using too little. Using too little R-0870 powder can throw off the results of the test. You need to use enough to bind to all of the chlorine that is present. Adding extra, within reason, has no effect. At very high FC levels it is likely that you will need to use more than the normal amount.
lovemy3azboys said:Thanks for the response... CYA was 80 just before we started the shocking process. We did some backwashing during the procees but still used the 80 CYA to calculate FC for Shock Level. I just ran the CYA test again & it looks somewhere between 50 - 60. I have read the CYA level at about 60 but wasnt sure if that was a false reading due to either algae or high FC. I'll let the FC level drop down to 18 (Pool Calculator) - 24 (Chlorine/CYA chart) unless someone has any other ideas I should try first. Here's hoping for a zero FC loss tonight!
At your high FC levels you may need two scoops. Here is the link to the extended directions for the FAS-DPD test: http://www.troublefreepool.com/extended-test-kit-directions-t25081.html#p206393[/quote:3hgfmyn4] Thanks for these additional instructions... I did read somewhere on here about hitting the bottom of the arch at the line rather than the top of the arch so I have been doing that. Good to know I can use more of the powder & it doesn't make a difference. With my FC so high I've been adding 10 drops at a time then swirling. Didn't think it would hurt if I did it the same every time. I'll work on adding each drop & swirling faster.linen said:I think jblizzle's approach is a good idea. Also, make sure that when you fill the test chamber, you fill it to the exact same level each time, I sometimes us a syringe for this. Two possible relevant items from the extended test kit directions:[quote:3hgfmyn4]The exact amount of R-0870 powder used is not critical. The goal is to add more than you really need rather than using too little. Using too little R-0870 powder can throw off the results of the test. You need to use enough to bind to all of the chlorine that is present. Adding extra, within reason, has no effect. At very high FC levels it is likely that you will need to use more than the normal amount.When measuring high FC levels, or measuring FC when the CC level is relatively high, it is important to move through the test quickly. Drops should be added about once per second, or slightly faster, swirling the entire time. You can slow down a little at the end of the test, to give you time to watch for the end point.
jblizzle said:lovemy3azboys said:Thanks for the response... CYA was 80 just before we started the shocking process. We did some backwashing during the procees but still used the 80 CYA to calculate FC for Shock Level. I just ran the CYA test again & it looks somewhere between 50 - 60. I have read the CYA level at about 60 but wasnt sure if that was a false reading due to either algae or high FC. I'll let the FC level drop down to 18 (Pool Calculator) - 24 (Chlorine/CYA chart) unless someone has any other ideas I should try first. Here's hoping for a zero FC loss tonight!
Sounds like a plan ... although it may take a day or 2 to drop down to around 20ppm.
jblizzle said:Just be consistent with how you test now... especially in the morning to compare with what you did tonight.
Later when you are a normal FC levels you can return to the single scoop.
Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
