Hey guys! First time using a FAS-DPD kit and I am just wanting to make sure im doing this correctly- I did the powder amd moved on to the titrate, the instructions say the solution will turn clear, however this is as clear as I was able to get my solution (picture attached). Is this as clear as it will go? It is still a bit tinted and not as clear as the starting water. At this point I stopped adding drops and moved on to the CC test. Following that, I did a second test to see if I stopped too early and my FC was actually higher but adding more titrate drops actually turned my test water more pink. I rinsed my tube and got new water between tests. Is this the color the solution should be when it’s “clear”? has anyone else had this happen?
