This is my third year at this whole pool thing. Each season I begin to figure things out, then it's fall and I forget EVERYTHING the next year!
The pool guys opened my pool and poured in 2 1/2 gallons of "shock". Now I wish that I had tested beforehand, but...
So after this "shock", my FC was 13, CC .5, CYA 0, pH blood red (couldn't get reading), and TA was 100. (Calcium 170 and salt 1200)
I started on the process of SLAMming, but did it all wrong when I raised my CYA too much... like to 55. When I went to see how much chlorine I needed I realized why you should only raise CYA to 30!
Then, I decided to raise my chlorine up to match the CYA, and checked the chart on TFP, but there are no numbers for salt water pools. I guessed I should go by the regular numbers. So I added more chlorine ... up to 15.
Then, I reread that you should first balance pH, but also that pH is inaccurate when FC is over 10!
Now I am rethinking ALL of this... and begging for help.
1. Do you always need to SLAM at pool opening? I am doing it wrong now (hit and miss) but the pool is clearing.
2. SLAM says that there can not be any loss of FC overnight, but I am confused because isn't there always a downward drift from a high FC level?
3. Very weird... my CYA numbers have dropped in the past 12 hours... like from 55 to 35. Is that possible or is it just my misreading?
4. Should I put in SOME acid to drop my pH. (Each year I have a HUGE problem, which I will need to ask about later) of constantly using acid, so I assume that I would have had to do this anyways (if I had tested before the chlorine).
5. Finally, how long should I run the filter for? (As in, should I be SLAMming still?) My husband is nagging that I need to give it a rest.
A HUGE AND SINCERE THANK YOU BEFOREHAND TO ANONE WHO TRIES TO HELP ME!!!!!!!!!
