I've about had it with my IC-40(s). I have to replace flow switches almost yearly or I get either the no-flow or flashing lights. I've had to replace the entire unit twice in 8 years. I'm overall fed up, but I don't know if there's a better alternative. Is there a viable replacement without having to change my plumbing? I see a bunch of ultra-cheapo options on the internet but that sounds like a bad idea when you're running an ongoing chemistry experiment with water, electricity, and chlorine gas.
Alternatively, is it worth trying to fix what I have, or should I just purchase another new one? I'm tempted, especially now that they extend the 2-year warranty even to self-installation (previously this wasn't an option). But I hate how expensive they've gotten.
My 2016 cell (bought new by the person selling us the house)replaced a 2014 cell the previous owner had let freeze one winter. In 2018, I had the flow switch replaced by a pool store due to the flashing lights and no-flow issue. One year later, it had the same symptoms so I decided to just purchase a new one, especially since there had been some major algae issues during the house purchase and the water chemistry was all out of whack by the time I took over (prior to finding TFP).
So, my 2019 cell, purchased from Amazon, worked fine, and all my water had been replaced along with the pool liner, and I had been following TFP methods so chemistry has been perfect for the most part. Exactly one year and a week later, the lights happened again, out of warranty. Since it was now 2020 and everything was shuttered, I bought an aftermarket flow switch from Amazon (non-Pentair I assume, since the wire gauge was different. It worked fine, though the flow light would stay green regardless of flow. Dangerous, so I kept the pump running 24/7. Things worked fine for the most part.
Last year, right as the major supply chain issues were happening, the 2019 cell died entirely. No lights at all. Local shop wasn't open anymore. If you could find a new IC-40, it was $1500+. On a whim, I said a prayer, re-installed the 2016 cell and wouldn't you know it just worked fine? No idea why, but I didn't question it. Of course, this year it is back to saying no salt, despite 3750+ppm and water at 74 degrees. Having learned my lesson in the past, I tried switching cells to the 2019 one again but it's still dead. Also having learned lesson in the past, I had another aftermarket flow switch (this time, OEM official part, supposedly) on hand. Did the swap, but it doesn't work either (says no flow). Don't know at this point if it's the switch or the IC-40 main board.
So... is it worth trying to either revive the completely dead 2019 cell, or to get the 2016 cell a proper flow switch? Is there a legitimate source for the pentair OEM switch? Comparing this OEM one to the cheapo aftermarket, it didn't seem much different. Or, should I just purchase new and be thankful for 2 year warranty? Or, is there a viable alternative brand I can consider switching to that won't be such a headache?
Edit: And/Or - is it possible I'm doing something completely wrong here to make all this happen? I keep my levels spot on, I've tested my TF-100 kit process with standards, I monitor often, and I generally keep my equipment running. Or are these units just this problematic with a weak link of a component that drives the whole thing?
