- Mar 7, 2013
- 17
Thanks for all the great info. I will review everything this weekend and see if I have any other questions. Sounds like chlorine it is. Now, I have to read the basics and figure out how it all works.
Again, we do not recommend UV for outdoor residential pools. It is just not needed and sometimes gives pool owners a false sense of security that their water is safe...when it might not be.Cassidy336 said:We are going to do the UV light with the chlorine.
Back to poolschool for you As jbliz said, UV will not reduce the level of FC that we recommend here. You may be confused by the discussion of cya. Pools following our cya/FC recommendations will have far lower "active " or disinfecting chlorine level then what is typically in commercial pools, while not compromising the water safety. For example, a pool with 0 ppm cya and 0.1 ppm FC will have an "active chlorine" level of 0.05 ppm. That same pool at 50 ppm (our recommendation for cya level) and 5.5 ppm FC will have an "active chlorine" level will again be the same 0.05 ppm. Contrast that with a typical public pool that has no cya and maintains a FC level of 3 ppm (this is common), there the "active chlorine" level will be 1.0 ppm (20X what we recommend).Cassidy336 said:According to the UV folks, we can have chlorine at about .5 which is supposed to be 50-90% lower than normal. But, someone here said using the BBB method you only have .1 free chlorine, and isn't that less? So will the UV help us use any less chlorine if we do BBB? And, if I can use less, how do I know how much less?
The reagents used in the test kits are exactly the same. TF-100 will be a better deal, because the kit has different sizes of different reagents, and you get more of the ones you should use more. Dollar for dollar, TF-100 is a better deal. Plus, the owners of the company are the owners of this site, and their customer service is beyond outstanding.Cassidy336 said:I do have a few questions - what is the best test kit? I saw Taylor TF-100 and Taylor k2006 mentioned.
I'll let someone else answer this one. I'm in the Chicago area, and I wish I could swim year round.Cassidy336 said:We live in FL and are getting a heater so we should be able to swim year round. Is there anything I need to do differently since we won't ever be closing the pool?
For an outdoor pool, UV is ineffective. UV only sanitizes the water running through the chamber. The bulk pool water is still dirty, and the UV system can't work fast enough to clean the whole thing. It's a waste of money.Cassidy336 said:We are going to do the UV light with the chlorine. According to the UV folks, we can have chlorine at about .5 which is supposed to be 50-90% lower than normal. But, someone here said using the BBB method you only have .1 free chlorine, and isn't that less? So will the UV help us use any less chlorine if we do BBB? And, if I can use less, how do I know how much less?
Yes. So safe, that one never needs to bother with the Crud at the pool store and aforementioned magic water cleaner systems. Personally, I would rather use bleach, cyanuric acid, baking soda, borax, and calcium chloride from the hardware/grocery store than buy the fancy pool chemicals from the pool store. I know what's in the bags and boxes I buy from the hardware store.Cassidy336 said:Are all these other chemicals - CYA specifically, very safe? I realize you guys have researched all this.
Cassidy336 said:Lastly, we are leaving town for two weeks this summer. We have family who have pools and will check on the house, but not everyday. What do I do to keep things ok while I am gone?
