Hey everyone - hoping you can help me out here. I've been using the bromine method (3 step) listed in the sticky here but have been having trouble keeping TA and pH in line. For awhile TA was stable and pH was slowly creeping up. No problem and I would add dry acid every once in a while. But now it seems that TA is dropping and not stable at all. What could be causing it to drop? Is it the adding of bromine tabs in the floater? If so, do I just need to monitor and add baking soda to keep TA in line? I was expecting that TA would stay stable and then just dry acid every once in a while to bring down pH.
Also, my floater is just a cheap one with the twist adjuster and 2 holes in the bottom. I fully close the twister adjuster as the water comes in from the bottom holes and seems to dissolve the bromine tabs fairly quickly (add 2 or 3 tabs every 5 or 6 days). Is there a better floater I should look to get instead?
