So I'm getting my pool back up and running and have noticed there is a lot of algae growing on the grout lines between the tiles (all above the water line). It will scrub off easily with a wire or still plastic brush but the grout is also breaking up and/or sanding off when I do this. It also takes a long Rear time. Considering just raising up the water level a bit and SLAM'ing and then maybe it'll soften up/die and I can just use the pool brush.
I know I'm going to have to repair grout and tiles soon, so what would you do?
