- May 22, 2013
- 2,796
- Plaster
- Hayward Aqua Rite (T-15)
If it isn't a long way to drive it would be best to get it tested and then dump in the amount you need. It's also cheaper that way. "We" don't like using pool store numbers but you have to use what ya got.
The big thing is if you're dumping that much bleach in you are already doing a SLAM and it's best to keep doing it as otherwise if you let the FC drop it might all be a waste if the green gets a chance to come back.
You should have the kit early in the week. When you go to Leslie's for testing and they suggest something the easiest thing is to just say you still have some of "that" or you're pretty sure you do and need to check before you buy more. That line saved me more than enough money to buy my own kit !!
Be careful with the DE. It works great but if you have dirty water it can plug up the filter a lot faster than without.
They can't test it if it's high but as it gets eaten up by the stuff in your pool it's likely it's dropping. It will still tell you something and IMHO I'd rather have some idea where I'm at before I toss bottles of bleach into my pool.
