I have a couple questions on this Day 7 of my SLAM. First, some background...I did my first OCLT last night:
Sunday, 7:30pm (late dusk)
FC 21.5 (Shock target of 20)
CC 0
Monday, 5:30am (barely dawn)
FC 21.5 (whoop!!)
CC 0 (whoop!!)
But...still murky! Ugh! I go back at 9:00am, FC holding well @ 21.0 (UV burn-off? Partly sunny) & CC @ 0. A cup of DE has been in since the afternoon prior.
I have a little more time at 9:00am, so I do a long backwash/rinse, then set to recirc and pop the lid off the filter (valve is side mount, so no plumbing on lid). I unscrew plug to drain down some, rubber-band a baggie on the top lateral, and stick my hand down into the sand. I expect to feel crud, but, only pure sand do I feel. I wiggle my fingers around the rim of sand, move some around in the middle. No crud. I put the garden hose in, dipping into the sand in the middle and edges, water begins to overflow. Expecting to see crud come out, it is just nice clear water. I do the hose thing couple more minutes, dipping down and around, and no change, only clean water coming out. I'm running short on time and decide staying on the task won't give me any better results, so I button everything back up, do a long backwash/filter, and decide I need to query the Forum. There was maybe a 1 psi decrease from the prior post-backwash psi, so maybe it made some difference with the hose in the filter.
Question 1: Is the murkiness dead algae?
My filter sand seems clean, and I have been putting DE into skimmer (with socks on the baskets) following every backwash/rinse for the last several days with pump going 24/7 this entire SLAM. My shallow to about 7' is clear as I can see a couple gravel I missed the day prior. But, I can see the main drain's vents only with the pump off (i.e., no ripples from waterfall return). Otherwise, with waterfall spilling in, I can see only a white item (because I know where to look). Hopefully there will be an improvement tomorrow.
Now, my second issue. Since I didn't pass all 3 criteria, at 2:00pm I checked levels:
FC 17
CC 0
CYA 50
I pour in 2 gallons of 8.25% to get back to FC of 20. But now I'm calculating in my head: FC dropped by 4 ppm in 5 hours on a cloudy morning with showers, and now the sun is out and may stay out for another 4 hours.
Assumption: If FC stayed steady over night, then this morning's FC drop is from the sun.
Question 2: Will my FC always drop 3-4 ppm, each day, when I'm post-SLAM? Or, is this drop a result of my other levels?
Here's pre-SLAM levels last week:
FC 3
CC 0
pH 7.6
TA 70
CH 100
CYA 50
Maybe this is why the prior owner used 3" tabs...cheaper and easier to use for a pool this size? Hard to imagine going through 14 gallon jugs every week (vs. 4 tabs/week).
