Hi everyone, I've been a lurker for several years on this site, and want to start by thanking everyone for all the great advice that's saved me a lot of money! I hate to post another "I've got algae" message, but I'm hoping I can get some advice to keep the algae away.
I filled my pool in mid May from a stream, SLAMed it, balanced out the chemistry and everything settled down nicely within a week. I let the FC level drop to 8 then turned on the SWG. I'm running the filter 6 hours a day and SWG for 4 and this seems to keep the FC level between 8 and 9. (I know this is a tad high for a SWG system, but I was having some algae problems at the end of last season and I'm a bit paranoid now.) Now this has been a cold rainy summer so far here in New England, and the pool didn't really warm up until last week. After a couple of days with the water finally above 80 degrees, I noticed some green algae on the bottom. I vacuumed it out and checked that the chlorine levels were still in the 8 to 9 range. After a few more days of warm weather, though, the water was beginning to look cloudy and then within a day turned green. I ran a complete chemistry test yesterday and the numbers were exactly what I expected:
FC - 8.5
CC - 0.0
TA - 80
CH - 50
CYA - 70
pH - 7.2
(TF-100 tests)
My FC has been between 8 and 9 and CC 0 every time I've tested it since the initial set up.
I started the SLAM process last night and the green is gone this morning and the water is beginning to clear, so I think I caught the outbreak early, but I'm wondering if there's anything I'm missing to keep the algae from coming back? I mentioned that I had a similar problem last year near the end of the season, but I attributed that to a measurement error that lead to too high a CYA and since I was emptying the pool anyway I didn't pursue it. This year, I'm confident of my CYA level and have checked it multiple times to confirm it.
Also, I've seen it mentioned many times in the forums that pH tends to rise over time in a pool, but I have the opposite experience. I initially raised my pH to 7.5 and it has fallen over the last 6 weeks to 7.2.
Thanks in advance for any advice!
FC - 8.5
CC - 0.0
TA - 80
CH - 50
CYA - 70
pH - 7.2
(TF-100 tests)
