Hello all,
Just opened the pool for the season. For the most part, everything seems to be running smoothly. Of course there is always something...I have a small amount of air coming in from the suction side. Nothing is noticeably leaking. The air bubbles stop when I close the main drain (3-way jandy valve) and pull from skimmers only. When I stop the pump, there is just a small air bubble (about 2 in in diameter) that sits underneath the pump strainer lid. I do not lose prime and no more air seems to collect in there.
Any ideas? Clog in main drain line? Crack in line underground? Valve leak? Should I do anything or just wait and see if it gets worse?
Thanks again for everyone’s help!
