- Nov 8, 2020
- 17
- Plaster
- CircuPool RJ-60 Plus
A friends pool has had an air leak for years with small bubbles coming out of the discharge ports into the pool. We just installed a variable speed pump and, not unexpectedly, the air leak is still there. I lubed up the o-ring on the cover of the new pump and that changed nothing. I'm tempted to disconnect the pump and rig a garden hose up to the inlet pipe and block off the same pipe at the skimmer and see where water leaks out of the pipe. Does anyone have a better / easier / faster / cheaper way to find the leak on the suction side line of the pump?
To me it seems pretty straight forward, but I could be missing something. I'm thinking the only way air could get into the system is on the suction side of the pump between the pool and the pump. Is there anything I'm missing?
Also, what is this item called (see photos)? I know what it does, but need to replace it and need the correct name.
Thanks in advance for any rendered help!!!!
