I am losing the little hair I got left. There is air in the pool, and the pump is not priming all way (1/3 of the pump basket has no water), and yes, the water level is mid-level to the skimmer. To try and fix it this is what I have tried:
JP
- Replaced the pump. The old was over 15 years old. The new pump is the INTELLIFLO3 VSF VARIABLE SPEED AND FLOW POOL PUMP
- . All the seals were checked, and no air leak was detected (tested with water and smoke)
- All the connections and values were replaced. Again, all the seals were checked, and no air leak was detected (tested with water and smoke)
- A professional checked every line for obstructions using air and water. Again, nothing.
- The skimmer was checked for air leaks, and nothing was found. However, it is the only piece of equipment that has not changed.
JP
