- Jun 18, 2012
- 55
- Plaster
- Jandy Aquapure 1400
Quick question about a solar heater.
I have a solar heater hooked up in line to my pool with an automatic valve that opens or closes based on temperature. Water goes from the pump to the cartridge filter, then either through the heater to the SWG or directly to the SWG, then to the pool. I also have a Polaris installed.
Every time the solar heater kicks on a tremendous amount of air comes out of the pool jets. I have never seen an obvious leak, and have had it serviced, but the air seems odd. Since it is a closed system on the pressure side I am not sure how air gets into the system. Is this normal for solar heaters? Is this anything I need to be concerned about?
TIA
TIA
