hello pool family
Since installation (2y ago) all have been working fine and when running variable speed pump at max and clearing air out of the cartridge filter top valve the pump basket reservoir has no air bubbles. Beautiful
over the last few days i started to notice air bubbles coming out of my pool return lines. Upon troubleshooting further seems it only happens on the pool suction line (MainDrain). Is still present If I manually close skimmer
That 3 way valve spins to close MD and allow for my SKIMMER and side wall VAC line to operate. Keep in mind when in vacuum mode and running at max I have NO AIR BUBBLEs whatsoever... I am perplexed where could the air intake be... I have no water loss (other than the standard South Florida heat/sun/wind loss rate.
it does not happen either on SPA Mode...
If this was a natural gas line and or air-line there are products to check leakage. But I don't know where to start to point-point the root cause and of course try to provide remediation.
your insight and input is very much welcome and greatly appreciated
