Currently, Pentair Whisperflo 1.5 hp 2 speed (wfds-6) but Highspeed won’t start on its own. Opened up the motor to check and also changed capacitor without success.
I am thinking of going with variable speed for the following reason:
1. Low speed is too weak to run the KK, and high speed, I think is too high. The reason I think it’s too high is because WHEN THE FILTER IS CLEAN, which I think has little flow resistance, the KK produces a lot of air to the filter. I think the KK is quite restrictive and the way it works, causing aeration (?) The problem goes away once the filter has ENOUGH DIRT IN IT that slow down the flow. Also, it’s a lot louder when the KK is running.
2. With VS pump, I hope I’ll be able to schedule the pump to run higher speed just an hr/day for the KK, and lower speed for the rest to save energy. Or just pick a minimum speed just enough to run the KK all day. Based on my experience with my current pump, 1hp would be good for the KK but having lower (.75?) when not using the KK and the higher 1.5 just in case is what I think ideal. i Like the KK because it has less moving parts with little maintenance required but the way it produces air I’m willing to go with something else.
3. Not having to redo the piping is also a consideration so should I assume that all pentair pumps have the same piping configuration? Is it possible to just change the motor and keep the wet end intact to minimize the work?
Currently, the pump is ran by Intermatic timer with Aquarite so with the new VS pump I’ll have to look into Current Relay Switch, or something like that for the Aquarite.
thx in advanice for your suggestions
