- Jun 22, 2014
- 47,861
- Fiberglass
- CircuPool RJ-45 Plus
That whirlpool is not good. Raise the water level until the flow is pretty rapid over the weir door but no whirlpool once in the skimmer. (you'll suck air)(though I just read it should be higher as we have a whirlpool going on in the skimmer)
Really a personal choice Pam. As temps are dropping in your area, many are closing their pools anyways. Some might just close and say ... "See ya next year filter!" Other owners might be the type who disconnect equipment and take it to the garage or somewhere out of the harsh elements, so they'll inspect a bit more. At the very least you'll have to drain the filter to prevent freeze and swelling/bursting. So that may be a good opportunity to either try a deep cleaning to see if it helps, or remove the sand and inspect everything inside. Again, it could go either way. You're learning a TON already, and have made great decisions to take charge of your pool. With water temps dropping, you're in a good position where you have some time to make choices based on your schedule. Don't let it overwhelm you. Post back with questions as you go and many here will be glad to help.Thanks, Tex, that was my thought. On the research I've done, plugged laterals came up, channeled sand, etc. That's why I didn't know if we should fix it now, or wait til spring. Was reading about the deep cleaning. Or if we should just start from scratch as if it were new.. Empty, take everything out, inspect lats, new sand, etc.
