Well, we had no idea we had this problem until the pool began to visibly leak from the exterior, last evening. The pool wall has a hole from rust. I’m thinking there had to be a very small leak that was undetected for quite some time to cause this damage. This part of the wall is under the deck and not visible, in passing. We had no idea this was happening.
So, the pool itself is about 13 years old and I can no longer buy the parts that connect the wall sections (not sure what they are called) and a lot of these are broken and are duck taped to prevent sharp edges around the rim.
We still have the original liner and were hoping to make it through the summer before putting in a new liner. It’s got quite a few patches but it has served us well. Now, with this issue I’m not sure what should be done? Could the wall be repaired or is this pool done for?
We are considering a substantial addition to our house and if that happens, the answer is easy and the pool has to go. However, this may be 1-2 years out, if it even happens?
I’ll be getting in the pool in a bit to see where it’s actually running out from. I know it’s there somewhere but the liner is still intact covering the hole. So, from the inside of the pool, the leak nor the hole can be seen.
Wondering if I can patch the liner on the inside and hope for another 5-6 weeks out of it? Can this wall section be repaired or is it better to call it a day with this pool and make plans for a new above ground pool or an in-ground pool, in the future?
