- May 3, 2007
- 16,964
- Plaster
- Hayward Aqua Rite (T-15)
Yes, that would work fine although you probably don't need a 2 HP pump for 6 jets at 60 GPM. But it wasn't clear where he is using the 2.5" pipe and where he is using the 2" pipe.6 single jets will run on a separate 2hp pump, 3 jet main fold will run with existing 1.5 HP circulation pump with valve control and still don’t know about the foot jets pump. Any suggestions to have 2 pumps instead of 3 ?.
So here is my suggestion. Use the 2.5" pipe or better yet 3" pipe for all 9 jets run off of the 2 HP Whisperflo (WFE-8). That pump should easily handle all 9 jets.
Then I would use the main pump for just the floor jets. I don't think you would need much flow rate for those.
