Re: Adding sand filter to 18' round Summer Escape pool - HEL
Yes, I'll take a couple, I would like to say that I've gone from disappointed to really happy in the last couple of days. my pool is clearer than it ever was with the old cartridge type filters, one thing I did was trim the opening for the pool input, the hose going from the filter pump to the pool, to accept the larger fitting. what I would like to do now is add the larger out port in addition the the skimmer, but I'm afraid the cut the hole and I'm not sure the right way to do it. If anyone has links or directions please post them.
zea3 said:robntex said:I'm disappointed with the Intex sand filter I installed today using the old pump (minus the impeller). It seems like I may not be getting even as much flow as I was with the stock pump and I'm not really able to vacuum with any significant suction using the skimmer plate. I thought it would be good to be able to vacuum to waste, as I was not able to do that using filter cartridges but this is not really any better.
Hi, can you post a picture of your current set up? Also please post a picture with the position of the multiport valve and the pressure gauge on the filter while it is running.
