- Sep 23, 2015
- 1,594
- Plaster
- Astral Viron V25
I added acid to my skimmer once, only once. I noticed a plume of dust comming out of the return jet and thought 'don't do that again'. Before finding TFP I had always done what I thought was best practice and diluted my acid in a plastic watering can and broadcast it around the pool surface with the pump running. I now feel I'm being a little lazy when I slowly pour it in front of a return.
|Edit - I keep thinking about this and wonder which method would ultimately mix the fastest, a full plastic bucket of diluted acid / pool water poured in slowly in front of a return with the pump on, a full plastic bucket of diluted acid / pool water poured in evenly arround the parimeter of the pool with the pump on or a full plastic watering can (same volume) of diluted acid / pool water broadcast over the surface of the pool with the pump on? Return, poured or broadcast? I'm thinking it would probably be in that order, return, followed by poured, and then broadcast. Any thoughts?|
