- Sep 6, 2018
- 76
- Plaster
- Jandy Aquapure 1400
Hello, current readings for gunnite pool…
FC 5
Ph 7.8
Cya 60
Salt 3300
CH 250
Temp 76
Water sparkling and clear
Pool math says to add 17 lbs of calcium chloride to raise CH to 350. What is the best process to add and will I raise the salt too high? Will I effect the other levels that I finally got perfect? Also, is turning the SWG to 0% enough?
FC 5
Ph 7.8
Cya 60
Salt 3300
CH 250
Temp 76
