Re: Adding acid, dialing back salt generator - TA going up?!
Readings this am show barely a trace of chlorine - this is with the SWG running on BOOST level 8 + hours.
FC .05 CC 1.
Given the past results -if I add 7 gallons of clorox, the FC will jump to 5, or more and the CC will jump by 1 ppm or so - then drop like a rock to almost 0 fc, and low cc.
I'm a bit concerned about the PH. It's been extremely low for a couple days now, and I'm wondering if I'm fighting a losing battle until I get the PH back up. It registers under 6.8. It also explains why my chlorine gets used up so quickly.
I'll see if I can bump that back up some and see how my FC levels hold.
BTW - TA is 30.
Pool caclulator says 9lbs baking soda for TA, and 11lbs of soda ash for PH. So - off to Walmart this AM to get some washing soda, and some baking soda.
Get the PH back up to 7.2 or so , and see if I can raise the TA back up after.
