I thought I would throw this out there in hopes someone has actually done this, and if it really helps specifically in a desert climate.
I have a 2 story house built in 2000, 2500 sq ft with 29 windows, most face south/south west. When we toured the house before buying it was 100 degrees outside and thermostat was set to 72. The house was great until you walked in the master, which was at least 10 degrees hotter with two 10 month old air conditioners. We purchased the house and replaced all of the windows, and patio door, the master became 5 degrees off. We added solar screens, now the bedroom is only 2 degrees off. The master is 1/3 of the upstairs, with vaulted ceilings and every single day it fluctuates 10 degrees, while the rest of the house only changes 2-4. If we keep the door closed, the Master is freezing or roasting but the rest of the house isn't really effected. We had an energy assessment by the power company and were told we were missing insulation in a small spot in the attic (not over master), and it was almost below code in some other spots, the rest was fine. No real numbers just " about 6-8 inches up there", which if I'm not mistaken is less than the requirements of R30-60, so not fine. They don't offer any incentives, so it's 100% out of pocket. The walls on super hot days aren't hot, so the last thing I can think of is attic insulation.
With all of that being said I live in zone 3 close to zone 2. On days where it's over 105, or below 50 degrees the house struggles, especially our bedroom. I get it's lava hot out most of the time, so it's the nature of the beast and I get there is a diminishing return if you go overboard. However, has anyone added insulation, if so from what r-value to final? Did it actually provide a noticeable difference? Is it more summer or winter you notice a change? Any information would be great, real numbers would be great too. I can only get estimates of 10-20% from energystar.gov, and most online posts elsewhere are for super cold climates.
