Pool service noob here... But is there really any reason to acid wash a filter? other than making it white? I mean I figure a normal rinse and clean would do the trick of cleaning it till you need to replace the filter? Why run the risk of mixing acid with water, ratio's, plus flushing that stuff everywhere in and after filling a garbage can? Just clean the filter without the acid??? Keep it clean till needing to replace filter.
