It doesn't work the way you think. Yes, it takes more acid to lower the pH when borates are present, but it also has the pH rise more slowly as a result. So the amount of acid that needs to be added over time is the same. You just need to add it less frequently.
It is the lower TA and the higher pH target that will result in less acid addition over time. The borates just have the rate slow down so that you add acid less frequently.
