Hi all, new to the forums. I am a new above ground pool owner. We had 1 cheapo above ground pool that lasted us about 2 season. This year we made the jump to a permanent 52” 18’ round Namco pool. The pool is being constructed on top of a cement slab my father built about 20 years ago for me to play basketball on. I’ve already checked and it is within 1/4” of being level. My question comes in 2 parts. First is there any reason I can’t put this pool on top of the slab in regards to bonding issues? I asked my father and he said he believes he used some left over black chain link fence in place of any rebar or wire mesh. Second part is, I know I have to run the 8 G bare copper bonding ring around the pool and connect it to 4 columns every 1/4 way around and then the pool pump. The slab is about 3 feet short in 1 direction and I will be adding on to the existing slab. I plan to drill into the old slab and install rebar to hold the slabs together. Does this rebar I add in need to be bonded together with the bonding ring I’ll be putting around the pools perimeter? Thank you all in advance for any and all help.-Wes
