EDIT: update and follow up question about plugging a skimmer hole in my reply below. Thanks!
Hi there, I was hoping to run my plan by you to make sure I’m not missing anything.
Owned the place about 7 years now. Last 2 years or so I have to add progressively more water regularly. Lately it seems like an inch a day. Much more in the summer than other times of year. We get plenty of rainfall here in Seattle outside of the summer, but even considering that the problem seems worse in the warm weather.
I have always suspected it is skimmer related because of the patches I see in there from the prior owner and because the water dropping rate is less after it get lower. But I haven’t been able to find anything with the syringe in prior years. But today I tried again and I’m now pretty sure it is leaking at least from the two locations I’ve highlighted in the photos.
My plan is to scrape off the old patches and use the epoxy I have (see photo) to try to patch those sections as best I can (which seems like it can be done underwater).
I am a bit of a novice at this so just wanted to see if there is anything I might be missing? Anything else worth trying at the moment? I’ve read many of the leak posts here so I think I’m on the right track but will take any considerations you’ve got.
Thanks so much for any advice!!
