I need to replace my failing pump. However, before I replace the pump I want to check if the sand filter installed by previous owners on my pool is adequate.
If I need to get a bigger filter then I may need a bigger pump. Based on the research I have done, I think I may need a 21-24 inch sand filter with 1.5 HP pump. If my current setup is adequate, I should be able to by the same 1 hp pump.
Current setup
24 ft round abg (~14500 gallons)
Heyward 180T sand filter
Hayward power Flo matrix 1 hp
~6 ft 1.5 inch hose from pool to pump
~2.5 ft 1.5 inch hose from pump to filter
~6 ft 1.5 inch hose from filter to pool
As always, thank you for your advice in advance!
Current setup
