Donldson said:
Something is not right with these results. You could not have passed the OCLT and then lost 31 ppm of chlorine during the day if your CYA is 120.
Don't know what to tell you... Last night and this morning's tests both agreed with each other to the exact ppm (and were roughly correct given the amount of bleach that I added to the pool according to the pool calculator). This evening's tests (both DPD-FAS as well as a quick confirmation check on a dip-strip) show < 2 ppm FC.
I did the CYA test 3 times, once as a halved test, once last night, and twice today. It is where I would expect given the amount of dichlor shock.
I guarantee I did the tests right, so short of me receiving a test kit out of whack with bad reagents (highly unlikely), we have something else quite weird. So, I don't know what to tell you - tell me which tests you want me to re-run, I'll do it again.
Then again, this year's entire experience has been out of the norm. The jelly-like clear-and-white blobs were growing at the rate of 1/2" on every single surface in the pool in 2 days after each time we tried cleaning it. The laterals and sand were all clogged with gloppy Crud. It took 200 lbs. of Chlorine (47% CalHypo) to oxidize it all (upon which it released from the walls and floor), a filter sand change, a lateral flush, etc. Then hourly we had to clean the gloppy stuff out of the skimmers and pump basket, resulting in 5 gallons of the jellyfish-like substance extracted from the worst point, then it took another 50 lbs. of dichlor and ~50 gallons of bleach since to keep it at shock levels.
My pool store says that they've seen hundreds of cases of this stuff this year, and the worst case they treated to this point required 6 treatments of borate/supershock at 2 week intervals with manual scrubbing/cleaning. I was told that mine eclipsed it by at least an order of magnitude. Samples of it were sent off to the chemical company, who didn't really have much to suggest other than to continue an attack with a very high borate level and very high FC level.
I told you it was a particularly challenging case... I now have a clear pool, I passed the OCLT, but I'm concerned about the inability for Chlorine to hold. I guess I'll just have to watch and see whether we get a reinfestation.
