Question for all of you that have autofill chambers with overflow. My autofill/overflow chamber has the bottom of the chamber there is the drain and supply water that goes to a fluidmaster fill valve. Inside the chamber is a stick of pvc pipe that is friction slipped into the bottom overflow connection side...it is not glued...like it could be adjusted with different lengths of replacement pipe if necessary.
Are these suppose to be glued in? it is a tight enough fit, that I dont estimate too much water loss...but there could always be some. How are you all's setup?
