Page 1 of 2 12 LastLast
Results 1 to 20 of 35
Thread: Come on in, the water is fine!
    Jul 2015
    Scotch Plains, NJ
    33
    Greetings everyone!
    My name is Steve. My wife and I just bought a new home with an existing in-ground pool. It is an 18 x 46, Sylvan cement pool, installed around 1964. We've just had a brand new Quartz finish applied, plus new tile and new brick coping. Our pool contractor is a very nice guy, but he's been less than stellar to deal with, to be honest. But that's another story...
    All of the work has finally been finished. We've already had some 3" tabs in the pool, and the water is crystal clear. Yesterday I took a sample to a local pool store. After getting a reading, they had me put in 5 gallons of liquid chlorine, 1 bag of stabilizer and 1 small bucket of PH decrease. I used an Aquachek "Free Chlorine" test strip. Today my readings are:
    PH - 8.4 or greater. Still too high.
    Free Chlorine - 10 or higher.
    Tot Alk - normal levels
    Stabilizer - normal levels
    To be honest, I have no idea of whether or not I should go swimming yet. From everything I have read, it's suggested that the high PH could be from my new paster. Also, the High FC seems fine, but likely I should wait for it to come down to normal? I have no chlorine smell and the water is not cloudy in anyway, so I assume CC is fine. Again I'm a total newb, so these are all assumptions.
    Anyway, good to meet you all, and if anyone has any immediate comments, I'd love to hear! Oh I have a 2.5 year old son, so I do not want to take any risks with when to OK him to go in water.
    Best,
    Steve
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Come on in, the water is fine!
    Welcome to TFP!
    I've removed your link as it isn't needed relative to your thread, and has the appearance of a promotion. I don't think you intended that, but just in case, it keeps you from making that appearance. Have a happy 4th, and enjoy the forum.
    Essential Links:
    Aug 2014
    Northern IL
    4,615
    With new plaster, doesn't your pool builder do your start-up to initiate a warranty?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    It is safe to swim when
    PH is 7.2 to 7.8
    Chlorine is above minimum level for your CYA
    Chlorine is below shock level for your CYA
    Water is clear
    Use the Chlorine CYA Chart to determine the correct chlorine level based on the CYA level in the pool.
    Jul 2015
    Scotch Plains, NJ
    33
    Thanks everyone. Appreciate all the immediate comments, especially on a holiday! Marian, my builder has been a huge disappointment, so sadly he's not been great in starting us up.
    Jul 2015
    Scotch Plains, NJ
    33
    Pooldv, this is very helpful. Thanks for that.
    Jul 2015
    Scotch Plains, NJ
    33
    Looks like my TA has dipped greatly. Reminder I added chemicals last night. So should I just wait it out or be concerned about TA?
    PH 9
    FC 10
    TA 30
    Stab 40
    Thanks in advance
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Steve, you should order one of the recommended test kits as soon as possible (TF-100 or a Taylor). Those pool store readings are likely not accurate.
    Also a good idea to not use any more tabs, just liquid bleach.
    Dolphin E10 Cleaning Robot.
    Jul 2015
    Scotch Plains, NJ
    33
    Thanks Borjis. I will take out the tabs for now and order a different test kit. Just wondering if the TA dip is cause for concern at the immediate moment. Thanks.
    1964 Sylvan 18' x 46' in-ground - 32,000 Gal - re-plastered June 14, 2015, Diamond Brite quartz plaster - Hayward DE 4820 Filter - 1.0 HP Emerson motor with a Hayward super pump
    DFW, TX
    24,509
    I wish I had more confidence in your test kit. That PH is bad and TA is bad. But, I am nervous about adding baking soda to raise TA.
    Use Pool School - PoolMath and be sure to enter your gallons, ph before 9 and after 7.5 and TA 30 and target 50 and hit calculate. Add however much muriatic acid it says to lower your PH. You may need to do this more than once.
    I think for now add 30oz of muriatic acid and 2lbs of baking soda, run the pump 15-20 min and retest PH and TA.
    Jul 2015
    Scotch Plains, NJ
    33
    Yes, I only have one of those $11 strip test kits. I just now ordered the Taylor K-2006 and will have it in two days. Tomorrow I will re-test and if nothing changes, your recommendations sound good. I would not be so worried if not for the new plaster job, but my pool guy has told me absolutely nothing so I am studying the internet for information like crazy. I appreciate this board and the experts taking their personal time to help.
    Thanks again.
    DFW, TX
    24,509
    Here is an article in Pool School about plaster start up, Pool School - Start-up New Plaster
    Which says it is important to keep PH below 7.8. I think you should add acid to lower PH.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    Hi Steve,
    welcome to TFP.
    you did the right thing ordering a good and extremely reliable test kit. It will be the best investment you make for your pool maintenence - bar none.
    I agree with pooldv. Get your pH down.
    New plaster needs to be taken care of properly. the pool school article should get you through that.
    Divin Dave,
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,619
    We have you covered! I was going to post the link for starting new plaster and BOOM there is was!
    You ALREADY ordered the test kit???? SWEET! That will save you so much heart ache!
    Get some muratic Acid. Make sure it is the 31% not the "safer" stuff. I get mine a Lowes by the pool stuff outside. NEVER store you MA anywhere your chlorine is or by any metal.
    You can get a little PH test kit from Walmart for cheap that will get you start on getting your PH down. It will come with a chlorine test as well. It will get you started on saving your plaster.
    We LOVE to see pics.............
    Kim
    Jul 2015
    Scotch Plains, NJ
    33
    Thanks everyone! One last question (probably not lol), is there a major difference between muratic acid and sodium bisulfate, or dry acid as it seems to be called? I've already put some of that into the pool so would like to know the main difference. Thanks again. You're all awesome.
    Kim here is pic. It turns sideways for some reason.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    Hi Steve,
    we recommend muriatic acid over dry mostly because Muriatic is less expensive per oz of active ingredient.
    More bang for the buck. Nothing wrong with using dry acid though.
    Chemically, I dont believe I could answer you question about the differences.
    Great looking pool you have there!
    Divin Dave,
    DFW, TX
    24,509
    Nice pool! Let's get that PH in line so you can swim!
    The only issue with using dry acid is that it adds sulfates to the pool which can cause issues long term. But, using what you have is no problem at all. Use it first and then switch to MA.
    Do store already opened bottles of MA outside in the shade somewhere. Inside or in the garage will cause corrosion to all things near it.
    Jul 2015
    Scotch Plains, NJ
    33
    Thanks again, everyone! I'll keep you posted on the progress. The family can't wait to swim, especially my little son who doesn't understand why we can't go in yet.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Long term use of dry a acid will build up Sulfates in the pool. In time and at higher concentrations Sulfates can be detrimental to plaster and or, they can build up to a point of forming Crystals as they come out of solution. Use up what you have and make the switch to 31.4% Muriatic. Congrats on taking a new step forward with. Proper kit, and welcome to the forum.
    Essential Links:
  20. Back To Top    #20
    Jul 2012
    Tallahassee, FL
    30,619
    OOOOOOOOOOOO AWWWWWWWWWWWW! That is a PRETTY pool! I love the shape and that accent on the steps!
    Please make sure to ask ANY question you might have. We LOVE to help!
    Kim
