Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Intex Ultraframe 22 x 52 pool
    Jul 2015
    Kansas
    19
    We bought a Intex 22 foot round pool. We eyeballed the ground and sat it up. It is now drained because it wasn't level. We have been reading and are very confused at the set up. Sand? No sand? Pavers under the feet? We live in Kansas and I really don't want to do this every year!
    Jun 2014
    15,189
    Re: Intex Ultraframe 22 x 52 pool
    Welcome to TFP. Yes, lots of options for the base of an AG pool. TFP has lots of threads on that subject. Some things to consider:
    - Soil/natural vegetation may determine base material
    - Some use sand only, Gorilla Pads, Astroturf, Foam panels, etc as a base flooring for comfort and/or liber protection
    - Pavers for feet support - sure. Some advise 2" thick because standard 1" may snap/break from pressure
    - Definitely make it level! Anything more than 1" out of level across can lead to excessive tilting and frame failure
    In the meantime, make sure you have a TF-100 test kit on its way to test the water yourself. Link below. Welcome to TFP!
    Jul 2015
    Kansas
    19
    Soil is dirt and packed with grass. Our back yard was a parking lot at one time. The new spot for the pool is three inches out of level. It is marked on the ground where we need to add dirt or sand. Should we dig out the grass? We did at our previous house, we had a doughboy pool.
    Intex Utra Frame 22 x 52 pool
    Jun 2014
    15,189
    I think it's most common to dig-out the high-end to make it a little lower rather than to try and build a new (false) higher side. If you type "Above ground pool base" in the search feature, you'll see different threads on what people used under their pool, why, and some pros & cons. Good luck!
    Jun 2015
    mississauga
    19
    we only have a 16ft, but we dug out the grass because it starts to smell really bad otherwise. I used the rototiller to loosen up the soil and level out the high spot, then used a tamp to flatten it all out.....It took about a week because we did it all by hand
    16ft x 48in Intex Ultra frame Pool
    1500 GPH krystal clear pump
    Located in Mississauga, Ontario, Canada
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I learned a lot from my first ultra frame:
    Blocks under the feet are necessary. (Used wood under my 18', using concrete patio blocks under the 26') They will sink after it rains a few times. Level the blocks with a transit. A friend lent us a laser transit, I could work on the pool alone when needed. Dig down, as stated, not build up. I Got a gorilla pad this time, it made it so much easier to get the wrinkles out when there was an inch of water. Still filling right now. We used a base of modified 2A, then sand, then the pad. Probably overkill, but we are setting up on the edge of a field, were worried about grass and bugs.
    Jul 2015
    Kansas
    19
    Sand or foam board? What is the foam board? I live over an hours drive from a home improvement store so I want to pick everything up in one trip. Thanks.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I used sand. Thought the taping, etc. wasn't worth the hassle, and it didn't seem to be much cheaper.
    Jun 2014
    Northeast Alabama
    98
    We put about 4" of sand on top of the clay base and it has worked very well for us. Use masonry sand, though, cause not all sand is the same.
    33 Round AGP, 26K gal, vinyl liner, 1 HP single speed pump, 1 Hayward wide mouth skimmer, Pentair sand filter, Taylor K-2006 test kit, Red Leopard Orbit suction auto vac, Pool School, TFTestkits, PoolMath, Support this Site!
    Jul 2015
    Kansas
    19
    Did you buy a load of sand or bags? If bags how do I figure how many to buy?
    Jun 2014
    Northeast Alabama
    98
    We used load sand and got about 10 ton to make the liner base we wanted but you wouldn't need near that much. Not sure how to figure with bags. We were told the pros and cons of sand prior to the purchase and we were told that 2-3" max were all that were recommended. Due to the size of the pool and the weight of the water, we decided 4" with more for the cove was the way to go. Everyone who has been in the pool has complimented the feel of the floor. It has no footprints, no wrinkles but does have slight ripples? but not so that it could be classified as dips or pockets. Kind of feels like walking in the shallows at the beach but firm. The auto cleaner has no issue with it at all.
    Jul 2015
    Kansas
    19
    What is a gorilla pad and where can I buy it?
    May 2015
    Chicago, IL
    508
    Gorilla pad is a fiber blend, kind of like a super heavy duty 1/8" thick landscaping cloth, but really tough. Do a Google search and you will find many places to order it from.
    Jul 2015
    Kansas
    19
    Our pool came with a ground cover. That isn't enough padding correct?
    CeltiaK's Avatar
    May 2014
    Western Mass.
    14
    Please research the sand base thoroughly. I've noticed that many who use sand also have hard-sided AGPs. The Intex design doesn't have any barrier to prevent sand from washing out from underneath. Unless you're planning to dig down 4", I think foam board or a gorilla pad would be the better option.
    Intex UltraFrame 18'x48" - 6700 gal as filled
    Intex Sand Filter Pump 2650 gph SF70110
    Intex SWG CS8110 (copper electrode removed)
    Hayward Dyna-Skim SP1091LX
    TF100 Test Kit from Day 1!
    May 2015
    Chicago, IL
    508
    Quote Originally Posted by Heavenrain View Post
    Probably not, they are just a cheap tarp, one of the thinnest ones available.
    Orlando, FL
    690
    Once you dig out all of the grass, level the ground, lay the provided tarp, and then place a Gorilla Pad, why do you still need sand? If you have money to spend, forget the sand and buy the foam board. The board would go instead of the Gorilla Pad and it gives you a nice, soft cushioned pool bottom.
    When digging for an AGP, a thin layer of sand can be used and then you go over it with a compactor or tamper (I think that's what it is called) to make sure it is compressed good. If you do not compress it , it will wash away with the first hard rain. On a hard-sided pool sand can be used but it is to keep the liner from getting under the wall- a completely different situation.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    May 2015
    Chicago, IL
    508
    Well you would not need a gorilla pad, the tarp provided and foam. I would go with the gorilla pad or the foam board, no need for both.
    titleistseemore's Avatar
    Jul 2014
    Lodi Ca
    189
    agreed, the need for both is not necessary. In my signature is my pool build which may give you some ideas with allot of pictures.
    Tim Jacobsen Lodi Ca.
    18'x48" Intex Ultra Frame (5700 Gallons)
    TF 100 Test Kit, Speedstir, & Sample Sizer. Liquidator Installed.
    Hayward C550 Cartridge Filter (55 Sq. Ft.), 1HP Powerflo LX Pump, Pool Rover Jr.
    http://www.troublefreepool.com/threa...uild-Questions
  20. Back To Top    #20
    jmcdtucson's Avatar
    Jun 2014
    317
    I don't advise using sand, at least not over 1" deep. Get your ground level and then you can use sand to smooth it out.
    If your sand is more than 1" deep, critters will dig under your pool into the sand to make their home. Then their home will collapse and you have a low spot. Ask me how I know
    Some folks use crusher run instead of sand. It holds together better.
    But the main thing is to dig down until your ground is within 1" of level from end to end. Then you can use sand or crusher run to smooth it out.
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
