Results 1 to 8 of 8
Thread: Broken valve handle
    Jun 2015
    Bedford hills ny
    46
    Broken valve handle
    I broke the handle on my Hayward valve. I have ordered a replacement. Is there any way I can adjust the setting without the handle? I am stuck on waste now....
    Sent from my iPhone
    20' x 50' AG gunite pool (no idea on gallons) built a long time ago. DE Filter w/Hayward Pump. Well water.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Broken valve handle
    It's going to be a little difficult, but I would try using a pair of Channel Lock pliers to see if I could tilt, and move it to a new position. You don't have much to lose by trying.
    Essential Links:
    Jun 2015
    Bedford hills ny
    46
    Thanks
    Jun 2012
    western NY
    1,560
    clamp a pair of vice-grips on the metal part in the center. pull straight up and turn. I've had to do it before too.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Better Idea danpik, thanks for the suggestion.
    Essential Links:
    Jun 2015
    Bedford hills ny
    46
    Thank you. Upon further review it appears that I broke the top of the diverter. Ugh.
    S1ngram's Avatar
    Jun 2014
    Chrisman, Illinois (East Central Illinois)
    304
    Do you have a submersible pump to put in your pool to keep the water circulating until you can do your repair?
    27' round Seaspray Evolution, AG, 17,100 gallons, Pump: Hayward Power-Flo Matrix Dual Speed 1.5 hp, Filter: Hayward Pro Series High Rate Sand Filter, June 18, 2014, Kreepy Krauley Lil Shark, TF-100 test kit, Intex Krystal Clear Saltwater System
    Jun 2015
    Bedford hills ny
    46
    No. I took the top off and locked it in position until the replacement can be installed
