Thread: Pump Losing Prime
    Jan 2009
    Atlanta, GA
    48
    Pump Losing Prime
    Is it common for pumps to lose prime when the water level drops below the skimmer and only the main drain is being used?
    Steve
    Atlanta, GA
    Inground Vinyl, 30,000 gallon, 20x40 Lagoon, Pentair Single Speed 1-1/2 hp Superflow, Pentair SD 80 Sand Filter, Polaris 280 cleaner w/ Booster pump, Pentair Easytouch.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Pump Losing Prime
    Depends on how the system is plumbed. Some skimmers are plumbed such that they share a line to the pad with the main drain so it is difficult to operate just the main drain in isolation.
    However, if the there are individual pool to pad lines with valves at the pad which allow for shutting off the skimmer and isolating just the main drain, then it should be possible.
    Mark
    Jan 2009
    Atlanta, GA
    48
    Thanks Mark. I feel dumb now because I never thought to turn my valve. My builder gave me that ability and now my pump works fine when the skimmers are turned to the off position. I do notice a few bubbles in the strainer basket when I shut the skimmers to the off position but I assume this isn't a problem.
    Steve
    Atlanta, GA
    mas985's Avatar
    Pleasanton, CA
    11,737
    When you shut off the skimmers, the suction will go up in the plumbing and pump suction side. Sometimes this will draw in air from the valves and/or pump lid. Usually, it is not a problem unless it gets to be so much air that you lose prime.
    Mark
