Results 1 to 11 of 11
Thread: New Pool Noob Here!
    Jul 2015
    Naples, FL
    16
    New Pool Noob Here!
    Hey there TFP! My name is Danny, I live in Southwest Florida, in Naples, specifically. You may have heard of it, if you're retired or have retired family members, they most likely live here haha.
    Anyway, my fiance and I just bought our first house. It was a foreclosure, and a bit of a fixer-upper. It has an inground pool in very poor condition, which I remember vaguely things my dad taught me about it when i was younger, but not nearly enough to maintain my pool....trouble free lol...So needless to say, I will be a big pain in your butts until I get the hang of this!
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: New Pool Noob Here!
    Welcome aboard, and congratulations on the new domicile and pool. Ask away we are all pool owners like you. Please get a good test kit, there is a link in my signature. Also start reading the pool school also linked below. We want pictures and water numbers asap. One last thing, don't get pool stored
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Jul 2015
    Naples, FL
    16
    Thanks! I did make a post with pictures in the Algae prevention section. It's truly very bad. Only thing I have done with the pool store is buy chlorine! I have a test kit from Home Depot, I don't have if that's worth anything at all or if I should invest more into a kit. I got it because it looks almost identical to the one I had to use as a kid, so I went with familiar lol
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Trust me you need either a Taylor 2600 or the kit in the link below. Drop based chlorine tests are more accurate especially if the chlorine needs to be above 5.
    Jul 2015
    Naples, FL
    16
    I just did the measurements. 8100 gallons. So not huge, but it'll do once it gets treated and fixed properly! I will get the proper kit that you recommend, and I've been reading the pool school all morning.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Stock up on 8.25% bleach. Make sure it's regular not splash less or scented. Target or Walmart store brands are fine as long as they say 8.25% on the label.
    Jul 2015
    Naples, FL
    16
    Here is a little sample of what we are dealing with here. My post is still waiting to be approved. Not good, not good at all. We have been in the house for only a couple of days. The entire yard needs work, so we wanted to get the pool fixed so we could jump in to cool off while working outside in the "lovely" Florida heat.
    Edit: the post is now up in the Algae prevention section.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
    Here are some resources to give you an overview of managing your pool using our methods:
    1. ABC's of Pool Water Chemistry
    2. Chlorine CYA Chart
    3. Recommended Pool Chemicals
    4. Recommended Levels
    5. Pool Math
    Also check out the SLAM link in my sig - you will definitely need to do that to clear your pool.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    That pool will be sparkling soon
    Jul 2015
    Naples, FL
    16
    Is it recommended to fill it back up and start the SLAM process? As of right now the brushing is doing absolutely nothing to the algae.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    You can't slam till your kit comes in. We need accurate numbers to succeed in any slam.
