Thread: when do u heat your pool?
    MirellaJoe's Avatar
    Jun 2013
    Aurora, Ontario-Canada
    125
    Question when do u heat your pool?
    Next tuesday our heater will be installed ( propane) and since i'm new to this when do you normally turn your heater on? during the day? or do u leave it running all night?
    Intex Ultra Frame 16'x48" sand filter w/intex SWG.
    Pool Blaster Max Vacuum
    3rd year with Intex and no problems
    Pentair Mastertemp BTU 125/ propane
    Taylor K2006 Complete FAS-DPD
    Feb 2014
    Upstate, NY
    390
    Re: when do u heat your pool?
    I have a gas heater rated at 250,000 BTU's. It heats my IG pool approximately 2 degrees an hour. So, whenever I want my water temperature increased, I use this formula accordingly. Also, when I do turn on the heater, I have it set to 89*. It will shut off automatically at 89*. Hope this lil bit of info helps. Good luck.
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
