Thread: Help with pool cooler
    Split by moderator from HERE. jblizzle
    Why taking lots of hassles on our head, similar Pool Cooler or Pool mister I purchased from Amazon in just less $50.00 for my above ground, but there is also in ground Pool cooler / mister at just $ 35
    Worth money to spend than costly Pool Chiller.
    Unfortunately My summer escapes pool having a 45 Degree angular return jet, so I am looking some help to connect that angle with the pool cooler I purchased, Here is picture of my Pool adapter..
    Sumi
    Re: Dane's "How To" for a quick & easy pool cooler
    Quote Originally Posted by maxepr1 View Post
    No need to turn over the water 2 times. Just run your pump at night, you'll get the cooling and filtering all at the same time.
    How much $ have you spend by making this pool cooler?
    Have you calculated your labor and Parts?
    I trided to make one, but not spraying enough angle, and second main problem was, it has a
    lots of burs inside the PVC pipe, which were restricting the water spray,
    I would rather prefer to have ready made, i have seen the video on you tube, but forgot its link
    they were made in VMC computerized CNC machine, I will try to dig that link and post here.
    Sumi
