Results 1 to 8 of 8
Thread: Salt level keeps increasing
    Jun 2015
    Staten Island, NY
    5
    Wen I opened the pool my salt level was 3300ppm. I figured it would go down to between 2800-3200 on its own. Now one month later my salt is at 3800ppm and I did not add salt. How can that be? Please help. Thanks.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: Salt level keeps increasing
    And you tested with?
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    My guess would be that the salt may not have been fully dissolved and circulated through the pool when you initially tested the level. Bleach will add a minimal amount of salt also if you have had a lot of bleach that would affect it too.
    I would not worry about it unless it's making alarms go off on the SWG. It will decrease gradually as you top off water.
    What are you using to test your salt level? I use the Taylor salt test kit and it's very accurate
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Jun 2015
    Staten Island, NY
    5
    I'm bringing a sample to the pool store salt meter.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Quote Originally Posted by Sgaleota View Post
    They are an unreliable testing source. We don't recommend the use of pool stores here other than to buy liquid chlorine.
    I recommend you invest in a TF 100 pool test kit and a K1766 salt test kit. They are both linked in my signature.
    Lisa
    JoyfulNoise's Avatar
    May 2015
    13,250
    What kind of SWCG do you have? (You should update your signature with pool equipment info).
    Many SWCG's are not temperature compensated. As the water heats up during the swim season, the conductivity of the pool water increases and many SWCGs show that as a higher salinity. Some units are temperature compensated and have a built in temperature probe so that the electronics can apply a correction factor.
    Either way, it doesn't really matter. All that matters is if the cell is reporting normal operation. SWCGs have very wide operating margins and produce chlorine over a wide array of water conditions.
    Matt
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Right! If the SWG is happy and making chlorine then we're all happy.
    Please add your pool info in your signature as shown here, Pool School - Getting Started
    Jun 2015
    Staten Island, NY
    5
    Thank you!!! I understand.
    14x24 IG vinyl pool,Jandy 1hp pump, Jandy cs250 cart filter, Jandy heater, Hayward Aquarite T9 SWG, ColorQ Pro7 test kit
