Results 1 to 10 of 10
Thread: Pump T R O U B L E
    Mar 2013
    TN
    178
    Pump T R O U B L E
    last Thursday night my youngest girl had some friends over for a night swim. In the process of trying to turn our 4 corner fountains on she turned the intake off on the pump. Don't think it ran long that night like that cause it is on a timer that turns off around 8. So I go to work the next day and come home for lunch and pool water isn't circulating. Walk out there and open easy touch and water temp is 150. Panic is slowly setting in. That is when I found intake valves closed. I opened them and turned pump back on and everything ran fine but had a leak on the outlet fitting of the pump. Also I was getting air in lines real bad. I Replaces seals in the strainer basket and replaced the one on the outlet of the pump. Had to leave pump off for 24hrs to let silicone set up. I checked it today and I have a small drip on outlet side of pump that I think silicone will stop but the air is still getting in. I have sprayed soapy water around fitting but see nothin. Of course a leak would suck not blow. Also my FC level went to 0 by being off all day. I am hoping that will come up now that pump is on.
    How do I find that leak? Also will my Polaris 280 work with air in the system. It didn't seem to want to go to the bottom and clean like it should.
    Ideas please.
    20x49 double roman 3.5' to 8.5 deep', 44,000 gal. SWG, TF-100 test kit with speed stir, concrete walls with vinyl liner, cartridge filter on an IG pool with a 1hp main pump and 1.5hp booster pump. Pool built April 2013
    Re: Pump T R O U B L E
    The hot water caused the pvc threads going into and out of the pump to shrink and lose the seal. You should replace both.
    Support the site
    Mar 2013
    TN
    178
    I will try that and report back.
    A good way to find an air leak is to have someone turn off the pump while you're carefully watching the spot where you suspect a leak. When the pump shuts off, there's a temporary burst of pressure that will sometimes squirt out of the leak spot. Try turning the pump on and off a few times while observing closely.
    Support the site
    Jun 2014
    15,189
    In addition to the comments above, it seems as if you have two issues now: A small water leak on the outlet of your pump (pressure side) and you say air is "still getting in" (suction side). So if I'm reading your situation correctly, the water drips on the pressure side should be easily identifiable and as noted above would probably require new seal(s). If you are still getting air in your lines, have you exhausted everything noted HERE?
    That's a shame it happened, and I hope you get everything resolved soon. Good luck.
    Mar 2013
    TN
    178
    Re-plumbed the intake last night and the air leak appears to be stopped. Still might have a drop on pressure side, gonna check that out further.
    Did notice on my filter that the spout on top where you can open and get air out has a drip now. Hopefully that is just some kind of seal. Don't think the two are related.
    Jun 2014
    15,189
    fixing that suction side leak. Those can be pesky. A little drop here or there on the pressure side isn't the worse thing. Not sure about your air relief valve, but my Hayward sits on top of a small seal.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    This maybe overkill but you may want to change out the shaft seal.
    Mar 2013
    TN
    178
    Quote Originally Posted by bobodaclown View Post
    Thought about that. Should I just get one to have it on hand since it's not leaking.
    Apr 2011
    Murrieta, CA
    2,360
    If it's not leaking you don't have to make more work, but keep an eye on it.
