Results 1 to 11 of 11
Thread: Can I lower my Blower bell?
    dissfigured's Avatar
    Oct 2011
    Denton, TX
    51
    The blower for my spa is for some reason, 5 feet off the ground and right in front of my control panel.
    Any reason, I can't just cut that PVC pipe a foot or 2 shorter and lower it?
    In-ground, SWG, 20,000 Gallons, Attached spa w/ Spillover, Hayward system, Cartridge Filter.
    Dallas TX
    38,299
    Re: Can I lower my Blower bell?
    Not that I can think of.
    I see your location listed in your signature, but please add your location (City, State or City, Country) to your profile as described HERE so we can quickly see it. Thanks.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Mine is about 6" off the ground.
    If your pool is higher than the thing you'd need it higher to prevent water from draining out.
    Mar 2015
    Harvey, LA
    300
    Mine is 4-5ft too, but the only reason is because the switch for it is attached to the side of it, and there are bushes down low, so it was convenient. It's just a plain ole pipe below it, and I doubt cutting a few feet from it will cause an issue...if anything maybe slightly stronger bubble action in the spa?
    17.4k gallon IG pool with attached spa (spa itself is 730gal), Super Blue Diamondbrite plaster, Circupool SI-45+ SWG, BH/Hayward Cartridge Filter, 2hp 2speed Hayward Super II pump, , Jandy Valves, Waterway Skimmers, Rheem 400k Heater, Polaris 360 cleaner, built 2000+-, replastered June 2015, TF-100 kit---Here's my pool test reading history
    Ours had to be raised because it's a little down a slope and water was getting into it.
    Stupid pool builder should have known better.
    26,000 gallon in-ground salt-water pool & spa with rock slide and waterfall (2006), Aqualink RS with SpaLink, Aquapure salt generator, Jandy DE filter, Polaris 380 cleaner, Laars LT natural gas heater, 2HP spa blower, 2 x 2hp pumps (one for pool spa, one for slide and waterfall), 4x Jandy digital color 120V halogen lights in Austin, Texas
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Pipe should be at least 2 ft higher that the body of water it serves. Example: If your pool equipment is at the same elevation as the pool water level, and you have a 18"-2' raised spa, your blower could need to be about 4' off the ground (at the equipment). When the blower switches off there could be a "surge" of water that travels back up the air line, and this is why the blower needs to have that extra height to it, to keep water out of the blower motor.
    Factory Warranty Station for:
    38,299
    Interesting. Thanks Pool Clown!
    Mar 2015
    Harvey, LA
    300
    Quote Originally Posted by Pool Clown View Post
    That makes sense---I've read that some of these blowers have check valves that I would think would stop this from occurring, allowing a lower install point...is that always the case?
    Qwaxalot's Avatar
    Jun 2012
    439
    Quote Originally Posted by gilbee View Post
    That's great until the check valve fails.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    Mar 2015
    Harvey, LA
    300
    Quote Originally Posted by Qwaxalot View Post
    But then I get a shiny new blower! Lol.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    All true!
