- May 3, 2007
- 17,012
- Plaster
- Hayward Aqua Rite (T-15)
Not sure I understand what out are talking about here. Can you give some more details on which jets are not strong.Some jets are not that strong and probably those are from the jets so I haven't figure that out yet.
It sounds like the valves are not set properly. You want to have suction come only from the spa and return only to the spa. If you are losing water to the pool, then one of the valves is not set properly. That could explain why the floor jets are not working well too.he foot jets that were installed on the bottom are not that strong with circulation pump. I need some advice on this one. It is separate direct line connected with a valve to a main circulation pump. The way it operated is useless. The jets show some auction when I reroute the spa return to those jets but still not effective. I also noticed at that time spa losses water to the pool.
No. A waterfall pump is a low head pump and is not appropriate for spa jets. Are there separate returns for the spa? If not, then you probably could not use a separate pump anyway. You still need to have the filter and heater in the loop for the spa unless you want separate equipment from the pool.Would it be ok to cut this line and install separate waterfall pump to have some strong auction.?
What might help is if you have a schematic of the plumbing layout you could post.
