Thread: Travertine pool coping
    Jan 2015
    Tuttle/Oklahoma
    147
    Tumbled vs. Honed. Are there any pro's or con's to either or is it just purely personal preference?
    My Pool Build Thread: 21 x 40 Freeform Gunite Pool, 12" Tanning Ledge, 3.5 shallow graduating to 4.5, 8.5 deep end, 4' Waterfall which doubles as a diving ledge with 6' x 4' Grotto underneath, 670 sq. ft., 106 Linear ft., Rock Salted Concrete Deck, Pentair 520 Filter, Intelli flow 3 HP VS pump, (4) Color LED lights, Intelli-Chlor SWG, Hot Springs Vanguard Hot Tub with ACE and BT Sound System, ODK, TF100
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    Re: Travertine pool coping
    Personal preference.
    Filled or not filled is the other travertine choice.
    Filled is more an indoor choice to prevent dirt collection.
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
    Jan 2015
    Tuttle/Oklahoma
    147
    I was worried that the rougher texture combined with SWG would cause excellerated breakdown of the Travertine.
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    I'm a bleach dumper, so I would not be able to comment.
    If you plan to seal the coping, then honed might be better.
    I have you to look at the various sealing options for my tumbled field with honed coping.
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    We have tumbled / honed, not filled and a SWG. With any travertine by a SW pool, you are going to need to seal properly right away. Correctly sealed (routinely), SW should not be an issue for the stone.
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
