Thread: Leslies PhosFree
    Nov 2013
    North-Dallas Texas
    18
    Leslies PhosFree
    So when Leslies says the Phosphates are high over 100, should I use their PhosFree solutions they sell to lower it or what is recommended to lower Phosphates? Also what happens when Phosphates are high, does that induce algae?
    Thank you for your help.
    15K Gallons IG Plaster Pool 7-9 hours of sun, Pentair WF-28 2HP pump with Cartridge Filter with Pentair heater
    Polaris 280 cleaner
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Leslies PhosFree
    Phosphates don't matter one bit if you are maintaining adequate chlorine levels for your CYA. Yes, phosphates are food for algae but maintaining chlorine means there's no algae to eat the phosphates. It's like a restaurant with no customers. Reducing phosphate levels can be an option to allow for lower average FC levels for maintenance, but it's much more expensive than simply using the proper amount of bleach or SWG output.
    Isolated Spa - 345 Gallons
    Nov 2013
    North-Dallas Texas
    18
    OK that makes a lot of sense. Thanks for the feedback.
    Polaris 280 cleaner
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Over 100 would not be considered high, but even if they were 2000 PPB, good consistent FC levels will make it irrelevant. Non existent or dead Algae cannot utilize phosphates, so it does not matter.
    Essential Links:
    Jun 2014
    15,008
    Golden rule - Avoid the pool store for testing, advice, or products. You simply won’t get the advice/service you deserve and you will waste money on products your pool doesn’t need. Do not add anything to your pool other than what is advocated by the TFP site or its experts. You’ll have a happier pool, spend less time maintaining your pool, and probably save some $$ in the process. The following are short articles from this site that you will see linked in my signature below: Pool School, Recommended Levels (for YOUR pool), PoolMath Calculator, SLAM, and the Chlorine/CYA Chart.
    PS ~ Good luck with the weather tonight.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Dead algae eats nothing!
