Thread: Best Chemical Brands
    Jun 2015
    Melfort, SK
    6
    Has anyone else used the 'Brilliance' products that Walmart sells?
    Just wondering if they are good quality products.
    Hydroforce Simple Set Soft-Sided Pool
    12 ft x 12 ft x 30 in
    1,421 Gal
    5,377 L
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Best Chemical Brands
    Hey Thomas, welcome to TFP!
    I don't know those products, but we are mostly of the mind that using common things like plain Bleach and Muriatic acid to control major parameters is the best method. Much more than that, the most important thing we believe is understanding the fundamentals of pool care versus what products to use. Good to have you with us, so enjoy your time on the forums.
    Essential Links:
    Jun 2015
    Melfort, SK
    6
    Thanks
    1,421 Gal
    5,377 L
    poolnoob.ca's Avatar
    May 2014
    Georgetown, ON, Canada
    277
    Hi Thomas, it looks like they are spa products, not pool products, and are at walmart canada but not u.s. In the u.s. they are distributed in the states by "ClearCare" pool store dealers. They are made by Arch Chemicals, the company who also sells Baquacil and Poolife brands. They have a range of bromine and chlorine products, pH and calcium adjusters, cleaners etc. Without having a hot-tub myself, i would say that it would be similar to using "pool-store" pool chemicals instead of the TFP method chemicals.
    http://www.brillianceforspas.com/our...intenance.aspx
    32,000L Fibreglass Leisure Pools IG 12.5'x23'x5' Pump: AstralPools BX1 1.0HP
    Filter: AstralPools ZX-310 SWCG: AstralPools VX7T
    Heater: Hayward H250FDN Test Kit: TF-100
    Jun 2015
    Melfort, SK
    6
    Ok, Thanks.
    1,421 Gal
    5,377 L
