Results 1 to 10 of 10
Thread: Broken outlet?
    Jun 2015
    San diego
    8
    Broken outlet?
    So I just got done building, filled up the pool and did the initial filter procedures but when I started to filter I noticed something odd. The water outlet is letting water come out some of the holes. Does anybody have this problem?
    Re: Broken outlet?
    I just cut new holes to use these exact intake and return and my head does the same thing. Pressure is awesome but it shoots water out of the sides as well.
    I am afraid to unscrew as I just cut the holes and don't want to break the good seal i have.
    Just upgraded from Intex 15x48 to Pro Series 22x54
    2500gph Intex sand filter
    Intex Krystal Clear Saltwater System
    Located in Boston, MA
    Jun 2015
    San diego
    8
    Re: Broken outlet?
    Where did you cut the holes at? Pics?
    Intex 18x52 above ground pool with a Krystal clear sand filter
    Re: Broken outlet?
    I can take some pics for you. I just upgraded to a 22x54 summer escapes pool that came with a skimmer. i did not want to use the skimmer with my sand filter so I had to cut new holes for the intake and return. After a few dozen reads and youtube videos I bit the bullet and did it. Everything is working great aside from some water spurting from the return like yours.
    Jun 2015
    Stockholm, Sweden
    250
    Re: Broken outlet?
    I have been told that you should point the 'eye' at a 45 degree left, 45 degree down angle. That way you create a vortex that makes the entire body of water circulate and brings up debris from the bottom to the skimmer. Looks like you should also raise the water level a bit so that the outlet is below the surface.
    Re: Broken outlet?
    Normal, my factory one does the same thing.
    May 2013
    Janesville WI
    74
    Re: Broken outlet?
    something obstructing the flow? What side do you have your gasket on?
    Intex 18x48/2650 Sand/56601E SWG
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,550
    Re: Broken outlet?
    That's normal. My old Intex eyeball did exactly the same thing. It's fine.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Jun 2015
    San diego
    8
    Re: Broken outlet?
    Yeah I did raise the water level and turned it to the left but I don't have a skimmer yet. If you guys have the same thing going then I'll be ok with it. Thanks
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,550
    Re: Broken outlet?
    Go ahead and look into a Hayward skimmer. They work much better than the over-the-wall Intex ones, and they come with a better return eyeball and a vacuum adapter too. Money well spent!
    Pentair IC40 SWG
