Results 1 to 7 of 7
Thread: Do I need a 2HP pump?
    Jul 2010
    Chillicothe, MO
    45
    Question Do I need a 2HP pump?
    We have a 30ft, 52 inch deep above ground pool. Our Super Clear 2HP pump that came with it has quit. Do I need to replace it with another 2HP?
    Thanks in Advance.
    Scwhitson
    24,500 gallon, round, above ground pool. Sand filter, ultraviolet light.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    Re: Do I need a 2HP pump?
    I would say no. At least get a 2speed and run it on low most of the time. Seems like a 1hp 2 speed pump would be fine. Or if you are in the market for a smaller VS pump I like this one, Pentair SuperFlo VS Pump 342001 | Pentair 342001
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Quote Originally Posted by scwhitson View Post
    Thanks in Advance.
    is this the type that you have? http://www.pool1.com/Filter-Pump.asp#J just in 2hp
    do you want to go back to an above ground type motor? is it 120v, 240 volt, hard wired?
    this one looks good but you will need to know what type Amazon.com : Hayward SP15922S Power-Flo Matrix Above-Ground Pump 2-Speed : Swimming Pool Water Pumps : Patio, Lawn Garden
    DFW, TX
    24,517
    Good point about above ground vs inground pumps, I missed that. Thanks.
    Jul 2010
    Chillicothe, MO
    45
    Quote Originally Posted by cowboycasey View Post
    Yes, the top one looks to be exactly what we have. The side of the pump says superclear 2HP. The pool is above ground, so not sure what you mean by going back to one? It is a 120v.
    Scwhitson
    Jul 2010
    Chillicothe, MO
    45
    Quote Originally Posted by pooldv View Post
    Well... that one does look good, but that's why I was wondering if I could go with a smaller one to bring the cost down.
    Thanks.
    Scwhitson
    Jul 2013
    Fletcher, OK
    3,353
    the pump from amazon is a 2 speed above ground 120v pump and would work perfect for you.. most people reviewed it on low speed between 2 or 3 amps on low
