Results 1 to 9 of 9
Thread: Would this work for Muriatic Acid
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    I found this at Walmart. Would it work for Muriatic Acid? Green Envy 610G1 Masonry Cleaner, 1 Gal.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    38,237
    Re: Would this work for Muriatic Acid
    Depends on the ingredients ... also check the strength as it could be weak.
    Looks like 20% acid plus urea and citric acid.
    Stick with regular muriatic acid.
    22,539
    According to the MSDS it has citric acid in it.
    It won't work in the place of muriatic acid for pools.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    I've been to 7 different stores hardware and big box and no luck finding it.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by pabeader View Post
    Well, the Lowes in W Marietta shows it in stock.
    Your order can be available for pickup in Lowe's Of W Marietta, GA today.
    Shop Jasco Muriatic Acid at Lowes.com
    JoyfulNoise's Avatar
    May 2015
    13,171
    Do you have a pool store nearby? Pretty much all pool stores carry muriatic acid. You might have to ask at the counter if it's not out with the general stock.
    Home Depot? Lowes? Ace Hardware? They should all have it as it is used by contractors for concrete etching.
    Matt
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    It also looks like the Home Depot in Hiram has 98 2-gal cases of 31% in stock. It says it's outside in the garden center but they will usually store it away from the other pool products due to compatibility.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    Jan 2012
    'burbs of Augusta, Georgia
    7,252
    'round these parts I get it at Lowes in the paint section
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Thanks folks! I didn't even think Lowes!! Between work and home I don't have one. Did end up at a local ACE and they had a small bottle. But since I only need 10 oz I picked it up. Will check out Lowes on Monday when I get paid.
