Thread: Chlorine Test
    Jun 2015
    Wamego/KS
    120
    Chlorine Test
    What is the difference between a DPD and a FAS-DPD chlorine test kit?
    25x16 rectangular in ground pool with vinyl liner (14,000 gal). Sta-Rite sand filter. 1HP single speed Max-E-Pro pump. Pool owner since 2013.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Chlorine Test
    The FAS-DPD test uses both a powder and a liquid reagent whereas the DPD uses only a liquid reagent. The big advantage of the FAS-DPD test is that it can read FC levels up to 50 ppm. In contrast, the DPD can read FC levels up to 5 ppm although it can read higher FC levels if you are willing to use diluted water samples. However, doing that can introduce more inaccuracies.
    The FAS-DPD chlorine test is the one you want if you desire to follow our methods.
    More information is available here: Extended Test Kit Directions - see posts 3 and 4.
    38,237
    Re: Chlorine Test
    You can read about all the chlorine tests here: Extended Test Instructions
